Downloads (Current Version)
| TitanNet Processor v15.1 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required. AvoKey must be plugged in before upgrading. |
Download 471.7 MB |
| TitanNet Processor v15.0 Recovery Creator | This is a recovery installer: – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Recovery Creator Guide
Download |
Documentation
| Go to Online Manual |
| Go to Release Notes |
| TitanNet Processor v15.0 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 276.7 MB |
| TitanNet Processor v14.0 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 255.3 MB |
| TitanNet Processor v13.0 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 190.2 MB 06/02/2020 |
| TitanNet Processor v12.1 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 177.2 MB 11/12/2019 |
| TitanNet Processor v12.0 Recovery Creator | This is a recovery installer: – To downgrade to previous versions, please see release notes. ⚠ Relicensing required, please allow 48 hours for upgrade. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Download |
| TitanNet Processor v11.4 Upgrade Installer | AvoKey not required | Download 122.9 MB 20/08/2019 |
| TitanNet Processor v11.3 Upgrade Installer | AvoKey not required | Download 122.8 MB 18/04/2019 |
| TitanNet Processor v11.1 Upgrade Installer | This is an upgrade installer: – Faster install and simpler install experience, allow 2 hours – Does not normally require relicensing. – Does not include additional performance increases from the recovery installer. |
AvoKey not required | Download 122.7 MB 17/08/2018 |
| TitanNet Processor v11.1 Recovery Creator | This is a recovery installer: – Improvements to performance, recomended for large shows – Longer and more complex install process, allow 48 hours ⚠Relicensing required, please allow 48 hours for upgrade. ⚠ Show files will be deleted, user backup of show files required. ⚠ Only one historical software version maintained |
Download 2.4 MB 26/09/2018 |
| TitanNet Processor v11.0 Recovery Creator | FTP Download | Download 3.3 GB 02/05/2018 |
| TitanNet Processor v11.0 Upgrade Installer | AvoKey not required | Download 121.6 MB 08/05/2018 |
Older Downloads
| TitanNet Processor v10.1 Recovery Creator | FTP Download | Download 2.8 GB 03/04/2017 |
| TitanNet Processor v10.0 Recovery Creator | FTP Download | Download 2.8 GB 12/06/2016 |
| TitanNet Processor v9.1 Upgrade Installer | AvoKey not required | Download 92.7 MB 28/07/2015 |
| TitanNet Processor v9.0 Recovery Creator | Download 2.3 GB 23/04/2015 |
| TitanNet Processor v8.1 Upgrade Installer | AvoKey not required | Download 84.5 MB 10/12/2014 |
| TitanNet Processor v8.0 Recovery Creator | Alternative Download | Download 2.4 MB 03/09/2014 |
| TitanNet Processor v8.0 Upgrade Installer | AvoKey not required | Download 84.4 MB 26/08/2014 |
ECNs
| Code | Title | Download |
| ECN-0208 | Titan Net Processor Hyper threading BIOS setting change | |
| ECN-0207 | Titan Net Processor Impedance Matched Ethernet | |
| ECN-0204 | Fix – Failed to create bootable BIOS Stick! (Error: 2) | ECN 0204 – Windows 10.zip |
