Illustrations
In this section you will find useful technical diagrams.
Some of the documents available in this section are in “PDF format”. This means that the files are compressed so they can be viewed or printed easily.
Pearl Upgrade Engraved Switch Caps Drawing
Visualiser – Midi port cableParts List Part Part No 2off 180 degree plug rs no. 234-1488 1off BC337 avo no. 05-02-0006 1off 9 pin bucket ch female avo no. 03-10-0021 1off D-Type9 hood (blue) avo no. 03-10-0041 4m cable arrow no. 038704R (25m)
Avolites Consoles – What fader?Console Master Fader Preset Fader Diamond 4 08-01-0400 08-01-0400 Diamond 2/3 08-01-0006(a) 08-01-0200 Diamond 1 08-01-0006(a) 08-01-0001 Sapphire 2000 08-01-0400 08-01-0300 Sapphire 97 late consoles (see note 1) 08-01-0006(a) 08-01-0200 Sapphire 97 early consoles (see note 1) 08-01-0006(a) 08-01-0001 Pearl 2000 type B above s/n 1435 (see note 2) 08-01-0300 08-01-0200 Pearl 2000 type A before s/n 1434 (see note2) 08-01-0200 08-01-0200 Azure 2000 Touch 08-01-0200 Azure 2000 Shadow 08-01-0300 QM consoles 08-01-0006(a) 08-01-0001 80/100 consoles 08-01-0006(a) 08-01-0001 RQ 30/60 consoles P&G mastering 08-01-0006(a) 08-01-0001 RQ 30/60 consoles non P&G mastering 08-01-0001 08-01-0001 Fader types Part Knob Narrow 08-01-0200 08-01-002x Wide 08-01-0300 08-01-002x Ruwido 08-01-0001 08-01-1000 Sellmark 08-01-0400 08-01-0035 Black short 08-01-0500 08-01-002x P&G 08-01-0006(a) 08-01-0007 Notes: Knob colours x = 7 red x = 8 blue 1 The fader was changed during but the serial number of the change is unknown. Check inside the console, if the faders are individually mounted then the faders are shown on the early consoles line, otherwise the faders are shown on the late console line! x = 9 white 2 If the serial number is near the one shown check with Avolites to ensure you are ordering the correct fader, or check the PCB which mounts the faders if it is 1201-4750A then the console is a type A if the console uses a pcb type 1201-4750B then the console is type B
MAP EurocardAvolites MAP Eurocards
There are two types of Eurocards on Avolites products.
The eurocard at the top is the ‘old type’ MAP5000A whilst the one at the bottom is the ‘new type’ MAP5000:
Riggers Remote Wiring Detail
Pearl 2000 Overlay
Boris motherboards
Boris Motherboard Links
Linking out the Grand Master on a PearlOnce the modification has been done, position the Grand Master Fader so that it at Full.
Borris I Motherboard – Wiring Detail
Floppy Disk Drive links
INVC196 Board Fuse Replacement
