Downloads (Current Version)
If you are updating from a software version below Titan V12.0, you need to run the v12.0 recovery before upgrading.
| Pearl Expert Titan v15.1 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required.
AvoKey must be plugged in before upgrading. |
Download 470.3 MB |
| Pearl Expert Titan v12.0 Recovery Creator | This is a recovery installer: – Support for AvoKey, must be plugged in before upgrading. – To downgrade to previous versions, please see release notes. ⚠ Relicensing required, please allow 48 hours for upgrade. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Recovery Creator Instructions
Download |
Documentation
| Go to Online Manual |
| Go to Release Notes |
| Pearl Expert Titan v15.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 276 MB |
| Pearl Expert Titan v14.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 255.2 MB |
| Pearl Expert Titan v13.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 188.1 MB 06/02/2020 |
| Pearl Expert Titan v12.1 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 175.3 MB 11/12/2019 |
Download |
| Pearl Expert Titan v11.4 Upgrade Installer | AvoKey not required | Download 114.6 MB 20/08/2019 |
| Pearl Expert Titan v11.3 Upgrade Installer | AvoKey not required | Download 114.6 MB 18/04/2019 |
| Pearl Expert Titan v11.1 Upgrade Installer | This is an upgrade installer: – Faster install and simpler install experience, allow 2 hours – Does not normally require relicensing. – Does not include additional performance increases from the recovery installer |
AvoKey not required | Download 114.4 MB 24/08/2018 |
| Pearl Expert Titan v11.1 Recovery Creator | This is a recovery installer: – Improvements to performance, recomended for large shows – Longer and more complex install process, allow 48 hours ⚠ Relicensing required, please allow 48 hours for upgrade. ⚠ Show files will be deleted, user backup of show files required. ⚠ Only one historical software version maintained |
AvoKey not required | Download 2.7 MB 26/09/2018 |
| Pearl Expert Titan v11.0 Recovery Creator | FTP Download | AvoKey not required | Download 3.3 GB 02/05/2018 |
| Pearl Expert Titan v11.0 Upgrade Installer | AvoKey not required | Download 113.3 MB 08/05/2018 |
Older Downloads
| Pearl Expert Titan v10.1 Upgrade Installer | Download 128.5 MB 24/03/2017 |
| Pearl Expert Titan v10.0 Recovery Creator | FTP Download | Download 2.8 GB 11/06/2016 |
| Pearl Expert Titan v9.1 Upgrade Installer | Download 116.1 MB 28/07/2015 |
| Pearl Expert Titan v9.0 Recovery Creator | Download 2.4 GB 23/04/2015 |
| Pearl Expert Titan v8.1 Upgrade Installer | Download 115.2 MB 10/12/2014 |
| Pearl Expert Titan v8.0 Recovery Creator | Alternative Download | Download 2.7 MB 03/09/2014 |
| Pearl Expert Titan v8.0 Upgrade Installer | Download 115.1 MB 08/09/2014 |
ECN’s
| Code | Title | Download |
| ECN-0204 | Fix – Failed to create bootable BIOS Stick! (Error: 2) | ECN 0204 – Windows 10.zip |
| ECN-0194 | SATA CD Drive Removal | |
| ECN-0191 | Dongle Connection Point Change | |
| ECN-0188 | Pearl Expert Touch Wing LED flicker | |
| ECN-0185 | Pearl Expert Hub USB input connector fixing | |
| ECN-0184 | Pearl Expert DMX Earth Connection |
