| ECN-0208 |
ECN-0208.pdf |
Titan Net Processor Hyper threading BIOS setting change |
| ECN-0207 |
ECN-0207.pdf |
Titan Net Processor Impedance Matched Ethernet |
| ECN-0206 |
ECN-0206.pdf |
Sapphire Touch Impedance Matched Ethernet |
| ECN-0204 |
ECN-0204.pdf |
Titan V9 BIOS and Shell Upgrade |
| ECN-0203 |
ECN-0203.zip |
Sapphire touch motor fader board firmware |
| ECN-0195 |
ECN-0195.pdf |
Sapphire BIOS setting for reliable Ethernet |
| ECN-0194 |
ECN-0194.pdf |
SATA CD Drive Removal |
| ECN-0193 |
ECN-0193.pdf |
LCD Inverter Enable Delay |
| ECN-0192 |
ECN-0192.pdf |
Fan Replacement |
| ECN-0191 |
ECN-0191.pdf |
Dongle Connection Point Change |
| ECN-0189 & 190 |
ECN-0189and190.pdf |
Mobile Fader noise and ref Voltage change |
| ECN-0188 |
ECN-0188.pdf |
Pearl Expert Touch Wing LED flicker |
| ECN-0186 |
ECN-0186.pdf |
Diamond 4 Video Drivers when using Commell LV677 motherboard |
| ECN-0185 |
ECN-0185.pdf |
Pearl Expert Hub USB input connector fixing |
| ECN-0184 |
ecn-0184.pdf |
Pearl Expert DMX Earth Connection |
| ECN-0180 |
ecn-0180.pdf |
Pearl 2008 BUM PCB Earth Link Connection |
| ECN-0164 |
ecn-0164.pdf |
Diamond 4 – EZ DMX Reset |
| ECN-0163 |
ecn-0163.pdf |
Diamond 4 – EZ DMX Power Modification |
| ECN-0159 |
ECN-0159.pdf |
Diamond 4 CPU fan bracket |
| ECN-0158 |
ECN-0158.pdf |
Diamond 4 LBA modifications |
| ECN-0157 |
ECN-0157.pdf |
Diamond 4 Motherboard Reset Cable |
| ECN-0155 |
ECN-0155.pdf |
Diamond 4 PSU Earth cable |
| ECN-0154 |
ECN-0154.pdf |
ART2000 T2 and T4 J1/J2 connector mating |
| ECN-0152 |
ECN-0152.pdf |
Running Hi-End Intellabeams |
| ECN-0151 |
ECN-0151.pdf |
Boris 3 Real Time Clock Mod |
| ECN-0150 |
ECN-0150.pdf |
Borris 2 Keyboard Interrupt modification |
| ECN-0149 |
ECN-0149.pdf |
A2K Ctrl Card Mains Capacitor Modification |
| ECN-0148 |
ECN-0148.pdf |
D4 EZ Borris Oscillator Modification |
| ECN-0147 |
ECN-0147.pdf |
Diamond 4 EZ DMX Oscillator Modification |
| ECN-0142 |
ECN-0142.pdf |
ART2000 T4 Connector panel Rib |
| ECN-0141 |
ECN-0141.pdf |
ART2000 I2C bus pull up |
| ECN-0139 |
ECN-0139.pdf |
Fitting Links on a Sapphire 2000 SMF PCB |
| ECN-0138 |
ECN-0138.pdf |
LCD Screens occasionally losing data |
| ECN-0137 |
ECN-0137.pdf |
Trimming the links on a Sapphire 2000 SMF pcb. |
| ECN-0133 |
ECN-0133.pdf |
Borris2 motherboards with ST9 adapter board |
| ECN-0132 |
ECN-0132.pdf |
Borris2 motherboards with floppy adapter board |
| ECN-0131 |
ECN-0131.pdf |
INVC196 Board Fuse Replacement |
| ECN-0130 |
ECN-0130.pdf |
Control fuse rating for ART2000 frames |
| ECN-0129 |
ECN-0129.pdf |
Watch crystal usage on MAP 5000C Eurocards and Borris2 Motherboards |
| ECN-0128 |
ECN-0128.pdf |
Azure Support Cable |
| ECN-0127 |
ECN-0127.pdf |
Floppy Adaptor Board |
| ECN-0126 |
ECN-0126.pdf |
ST90R40 Adaptor Board |
| ECN-0125 |
ECN-0125.pdf |
Hawke 1330IF (Screen Control Board) replacement |
| ECN-0124 |
ECN-0124.pdf |
Borris 2 reset line. |
| ECN-0123 |
ECN-0123.pdf |
ALG Video Card modification |
| ECN-0120 |
ECN-0120.pdf |
ART 2000 tray connector change |
| ECN-0119 |
ECN-0119.pdf |
ART 4000 Zero Cross window adjustment |
| ECN-0118 |
ECN-0118.pdf |
ART 4000 Main Card fixing |
| ECN-0117 |
ECN-0117.pdf |
Diamond II/III Encoders |
| ECN-0116 |
ECN-0116.pdf |
Pearl 2000 Roller Modification |
| ECN-0115 |
ECN-0115.pdf |
Borris 2 Crystal |
| ECN-0114 |
ECN-0114.pdf |
Azure PSU Earth Link |
| ECN-0113 |
ECN-0113.pdf |
Rack Splitter DMX Termination |
| ECN-0109 |
ECN-0109.pdf |
Pearl Disc Drive |
| ECN-0108 |
ECN-0108.pdf |
Tonya3 GAL |
| ECN-0107 |
ECN-0107.pdf |
Sapphire 2000 Lamps |
| ECN-0106 |
ECN-0106.pdf |
D2/D3 Real Time Clock |
| ECN-0105 |
ECN-0105.pdf |
Diamond Extended Memory |
| ECN-0104 |
ECN-0104.pdf |
Pearl DIL Extended Memory |
| ECN-0103 |
ECN-0103.pdf |
Azure encoders |
| ECN-0102 |
ECN-0102.pdf |
Pearl Midi Modifications |
| ECN-0101 |
ECN-0101.pdf |
Diamond Midi Modifications |
| ECN-0100 |
ECN-0100.pdf |
Borris2 Multiple Key Presses |
