Important Update
From Ai Version 11 onwards, a new software protection system is in place. Because of this current hardware will need a license update in order to allow you access to the new software, which is available via the new AvoKey. You will need to request an upgrade for the key and then an authentication process will be required in order to upgrade your existing servers/dongles from version 10 to version 11. The authentication is handled via a separate app called Authenticator.exe which is installed to Distrib/Avolites Authenticator. For more information see the Authenticator Guide.pdf
Please be aware that specifically Dell Alienware machines may not work properly with Ai software due to the Alienware Control Center (AWCC) service shipped with them.
Downloads (Current Version)
| Ai v12.1.9.6 | Ai v12.1.9.6 | AvoKey required | Download 566.6 MB 03/10/2022 |
| Ai v12.1.9.4 | Ai v12.1.9.4 | AvoKey required | Download 515.6 MB 23/11/2021 |
| Q3 v10.3 Recovery Creator | Urgent recovery update | Not required | Download 2.3 MB 25/03/2019 |
Synergy Download (Current Version)
| Synergy Upgrade v15.1 | Upgrade required for Ai to be compatible with Synergy in Titan v15.1 | Ai hardware requires AvoKey to run Synergy | Download 10.4 MB 13/04/2021 |
| Go to Release Notes |
| Ai v12.1 | Ai v12.1.5.2 | AvoKey required | Download 522.9 MB 16/04/2020 |
| Ai v12 | Ai v12.0.1.1 | AvoKey required | Download 662.9 MB 14/10/2019 |
| Ai v11 | Ai v11.0.2.1 | Avokey required | Download 753.8 MB 08/08/2019 |
Old Downloads
| Ai v10.3 | Not required | Download 476.3 MB 10/09/2018 |
| Ai v10.2 | Not required | Download 489.4 MB 02/07/2018 |
| Ai v10.1 | Not required | Download 500.3 MB 01/03/2018 |
| AiM Adobe Plugin 2022 Installer (Mac OSX) | AIM Codec Dedicated Mac Installer. For installation of the Adobe CC 2022 | Not required | Download
190KB 13/07/2022 |
| AiM Adobe Plugin 2022 Installer (Windows) | AIM Codec Dedicated Windows Installer. For installation of the Adobe CC 2022 | Not required | Download
1.24MB 13/07/2022
| AiM Codec v1.3 Windows Installer | AIM Codec 1.3 Dedicated Windows Installer. For installation of the Adobe CC 2019 plugins and the quicktime component | Not required | Download 1.4 MB 03/07/2019 |
| AiM Codec v1.3 (Mac OSX Manual Install) | AIM Codec 1.3 Manual OSX Components. For installation of the Adobe CC 2019 plugins and the quicktime component. | Not required | Download 150.5 KB 18/09/2019 |
| AiM Codec v1.3 (Windows Manual Install) | AIM Codec 1.3 Manual Windows Components. For installation of the Adobe CC 2019 plugins and the quicktime component. | Download 286.3 KB 03/07/2019 |
| Ai V10 Installer | Version is fully featured, but it will flash white on all outputs every 2 min until a dongle or software licence is installed. If after installation you get a message saying MSVCP120.dll is missing, please use the installers found in Distrib/Sytem/MSVC | Not required | Download 692.6 MB 11/10/2017 |
| Ai V9.1 Installer | Please also install the NDI sdk which can be downloaded for free from NDI Developers | Not required | Download 512.3 MB 03/02/2017 |
| Q3 v10.3 Recovery Creator | Download 2.3 MB 25/03/2019 |
Documentation
| Name | Download |
| Ai v12.1 User Manual | Download |
| Ai v12 User Manual | Download |
| Ai v11 User Manual | Download |
| Authenticator Guide | Download |
| AiM Installation and Rendering Guide | Download |
| Ai v10.2 User Manual | Download |
| Ai v10 User Manual | Download |
| Ai V9 Manual | Download |
Synergy Downloads (Previous Versions)
| Synergy Upgrade v15.0 | Upgrade required for Ai to be compatible with Synergy in Titan v15.0 | Ai hardware requires AvoKey to run Synergy | Download 10.4 MB 13/04/2021 |
| Synergy Upgrade v14.0 | Upgrade required for Ai to be compatible with Synergy in Titan v14.0 | Ai hardware requires AvoKey to run Synergy | Download 10.4 MB 20/10/2020 |
| Synergy Upgrade v13.0 | Upgrade required for Ai to be compatible with Synergy in Titan v13.0 | Ai hardware requires AvoKey to run Synergy | Download 10.1 MB 06/02/2020 |
| Synergy Upgrade v12.1 | Upgrade required for Ai to be compatible with Synergy in Titan v12.1 | Ai hardware requires AvoKey to run Synergy | Download 10.0 MB 12/12/2019 |
Ai Installation Tips
Version 11 has a lot of dramatic changes under the hood which means that any older projects will not work. To help in upgrading your showfiles a project importer is built into version 11. To activate it you need to copy your old project into the Distrib/Projects folder. From the Ai software go to the project browser page and load the project from here. A popup box will ask you if you want to create a new v11 project based on your old project. This process will create a whole new file and leave your old showfile unaffected.
When installing a new version of Ai, it is advisable to either rename the existing Distrib folder or delete the Distrib folder altogether. If deleting the Distrib folder, please be sure to back up any user data in advance. Newer versions installed over the top of existing installations can create performance errors or system instability.
For help email: support@avolites.com
